- From: Arthur Azevedo de Amorim <arthur.aa AT gmail.com>
- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Function that transforms types
- Date: Fri, 25 Jul 2014 11:48:47 +0200
Hi Bruno,
You can solve your problem by using one level of indirection. Instead
of writing f : Type -> Type, you can define a type "code", together
with a function denote : code -> Type:
Inductive code :=
| Arrow : code -> code -> code (* Function type *)
| (*... other types *)...
Fixpoint denote (c : code) : Type :=
match c with
| Arrow c1 c2 => denote c1 -> denote c2
end.
having done that, you can then define f directly on "code". You'll
have to restrict your universe of types to do this, but this should be
enough for many applications.
Best,
2014-07-25 11:36 GMT+02:00 Bruno Woltzenlogel Paleo
<bruno.wp AT gmail.com>:
> Hi!
> I would like to implement a function that takes a type and returns another
> type.
> What I have in mind is something like this:
> (* wrong code below! *)
> Parameter i: Type.
> Fixpoint f(A: Type) := match A with
> | (A1 -> A2) => i -> f(A1) -> f(A2)
> | A0 => i -> A0
> end.
> I understand why this is wrong (in so many ways!).
> My question is: is it possible at all to achieve this kind of type
> transformation in some other way? If yes, how?
> Best regards,
> Bruno
- [Coq-Club] Function that transforms types, Bruno Woltzenlogel Paleo, 07/25/2014
- Re: [Coq-Club] Function that transforms types, Arthur Azevedo de Amorim, 07/25/2014
- Re: [Coq-Club] Function that transforms types, Cedric Auger, 07/25/2014
- Re: [Coq-Club] Function that transforms types, Daniel Schepler, 07/25/2014
