- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Function that transforms types
- Date: Fri, 25 Jul 2014 13:59:10 -0700
In addition to the option of providing an object which interprets to a
type, you could also use typeclasses to achieve something which looks
similar:
Parameter i : Type.
Class FTransform (A:Type) : Type :=
f : Type.
(* Make A argument to f explicit, but keep the instance argument implicit. *)
Arguments f A [FTransform].
Instance FTransformBase (A:Type) : FTransform A | 5 :=
i -> A.
Instance FTransformArrow (A B:Type) `{!FTransform A} `{!FTransform B} :
FTransform (A -> B) | 3 :=
i -> f A -> f B.
This isn't actually a function of only a type, but in fact it's a
function of an instance argument constructed automatically via an
eauto like procedure. The | 5 and | 3 provide precedence levels
(higher numbers mean lower precedence). So now:
Eval compute in (f (nat -> nat -> nat)).
= i -> (i -> nat) -> i -> (i -> nat) -> i -> nat
: Type
Daniel Schepler
On Fri, Jul 25, 2014 at 2:36 AM, Bruno Woltzenlogel Paleo
<bruno.wp AT gmail.com>
wrote:
> Hi!
> I would like to implement a function that takes a type and returns another
> type.
> What I have in mind is something like this:
> (* wrong code below! *)
> Parameter i: Type.
> Fixpoint f(A: Type) := match A with
> | (A1 -> A2) => i -> f(A1) -> f(A2)
> | A0 => i -> A0
> end.
> I understand why this is wrong (in so many ways!).
> My question is: is it possible at all to achieve this kind of type
> transformation in some other way? If yes, how?
> Best regards,
> Bruno
- [Coq-Club] Function that transforms types, Bruno Woltzenlogel Paleo, 07/25/2014
- Re: [Coq-Club] Function that transforms types, Arthur Azevedo de Amorim, 07/25/2014
- Re: [Coq-Club] Function that transforms types, Cedric Auger, 07/25/2014
- Re: [Coq-Club] Function that transforms types, Daniel Schepler, 07/25/2014
