- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] beta expansion of part of goal
- Date: Fri, 25 Jul 2014 12:42:53 -0400
On 07/25/2014 12:31 PM, Jonathan wrote:
On 07/25/2014 12:11 PM, Jason Gross wrote:
This is untested, but I think the following should work:
lazymatch goal with
| [ |- ?lhs = ?e ?x ] => let lhs' := (eval pattern x in lhs) in change
(lhs' = e x)
end
That works! Thanks. I didn't know that pattern was one of the tactics accepted by compute. But - now I see it in the refman (page 249-250).
By the way, reflexivity doesn't work on the result, but unify does via:
match goal with |- ?A = ?B => unify A B end.
Shouldn't reflexivity be doing that? Auto works as well, but since info_auto doesn't work, I don't know what auto did.
Oh - I forgot about debug. Using debug auto, it says that auto succeeded via apply @eq_refl, which is surprising since I though reflexivity did the same thing.
-- Jonathan
- [Coq-Club] beta expansion of part of goal, Jonathan, 07/25/2014
- Re: [Coq-Club] beta expansion of part of goal, Jason Gross, 07/25/2014
- Re: [Coq-Club] beta expansion of part of goal, Jonathan, 07/25/2014
- Re: [Coq-Club] beta expansion of part of goal, Cedric Auger, 07/25/2014
