- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Rewrite does not work
- Date: Sun, 27 Jul 2014 14:52:04 -0400
On 07/27/2014 02:24 PM, Marcus Ramos wrote:
Hi,
I have the following context/goal:
1 subgoals
g : cfg
n : nat
l : list sf
IHn : Datatypes.length (removelast l) >= 2 ->
(forall i : nat,
i <= Datatypes.length (removelast l) - 2 ->
exists (left : non_terminal) (right s s' : sf),
nth i (removelast l) [] = s ++ inl left :: s' /\
nth (S i) (removelast l) [] = s ++ right ++ s' /\ rules g left
right) ->
sflist g (removelast l)
H0 : Datatypes.length l = S n
H1 : Datatypes.length l >= 2
left : non_terminal
right : sf
s : sf
s' : sf
H6 : nth (Datatypes.length l - 2) l [] = s ++ inl left :: s'
H7 : last l [] = s ++ right ++ s'
H8 : rules g left right
H3 : Datatypes.length (removelast l) = n
H : Datatypes.length (removelast l) < 2
H5 : nth (S (Datatypes.length l - 2)) l [] = last l []
H9 : removelast l = [s ++ inl left :: s']
______________________________________(1/1)
sflist g (removelast l ++ [last l []])
and I get an error message when I try to "rewrite H7".
The message is:
Error: Found no subterm matching "last l []" in the current goal.
Which is strange, since "last l []" appears as a subterm next to the end of
the goal. A similar message appears if I try to "rewrite H9".
I can´t figure out why this happens and how to get my goal written as:
sflist g ([s ++ inl left :: s'] ++ [s ++ right ++ s'])
Thanks in advance for any help.
Best Regards,
Marcus.
One thing to always try when this happens is Set Printing All, and then redisplay the goal. Often, you'll see that the rewrite rule doesn't match the target anymore - due to implicit args and/or coercions. That's probably what is happening here.
-- Jonathan
- [Coq-Club] Rewrite does not work, Marcus Ramos, 07/27/2014
- Re: [Coq-Club] Rewrite does not work, Jonathan, 07/27/2014
- Re: [Coq-Club] Rewrite does not work, AUGER Cédric, 07/27/2014
- Re: [Coq-Club] Rewrite does not work, Pierre-Marie Pédrot, 07/28/2014
- Re: [Coq-Club] Rewrite does not work, Marcus Ramos, 07/29/2014
- Re: [Coq-Club] Rewrite does not work, Cedric Auger, 07/29/2014
- Re: [Coq-Club] Rewrite does not work, Enrico Tassi, 07/29/2014
- Re: [Coq-Club] Rewrite does not work, Xavier Leroy, 07/30/2014
- Re: [Coq-Club] Rewrite does not work, Jonathan, 07/30/2014
- Re: [Coq-Club] Rewrite does not work, Xavier Leroy, 07/31/2014
- Re: [Coq-Club] Rewrite does not work, Jonathan, 07/31/2014
