coq-club - Re: [Coq-Club] Rewrite does not work
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Rewrite does not work
  • Date: Thu, 31 Jul 2014 13:28:26 -0400
On 07/31/2014 12:48 PM, Xavier Leroy wrote:
On 30/07/14 20:11, Jonathan wrote:
How about this stop-gap proposal: define an unfold hint db to which users
can add their own hints, and which is used by Coq in cases like rewrite and
omega (and I'm sure plenty of others). Or, slightly better - have a setting
like "Add Implicit Autounfolds dbname" so that multiple different hint dbs
can be used.
Thanks for the suggestion. It could work pretty well for my uses in
CompCert, because I have relatively few type aliases and they get
reused a lot. But Coq beginners would still be baffled, first by the
mysterious failures of rewrite et al, then by the need to build an
unfold hint db...
Why just a stop-gap and not a proper fix?
What would a proper fix be? Sometimes, you want rewrite (and other tactics) to not do certain conversions. That means that something is needed to distinguish between the conversions you want to be automatic and those you don't.
Maybe use Strategy levels somehow?
-- Jonathan
