- From: Marcus Ramos <marcus.ramos AT univasf.edu.br>
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Symmetry does not work with <>
- Date: Mon, 28 Jul 2014 17:10:12 -0300
Hi Guillaume,
That´s not the case, but thanks anyway for sharing your code.
Best Regards,
Marcus.
2014-07-23 9:39 GMT-03:00 gallais <guillaume.allais AT ens-lyon.fr>:
Hi Marcus,
If you use symmetry on inequalities quite a lot in your proof scripts,
you should probably define a wee module making [symmetry] work for [<>].
Here is the way we've done it in Coqtail:
https://github.com/coqtail/coqtail/blob/master/src/mytheories/MyNeq.v
Cheers,
gallais
On 22/07/14 21:46, Marcus Ramos wrote:
Hi,
My goal is "l <> []", however I need it to be "[] <> l". How can I get
this since symmetry does not work for <>?
Thanks,
Marcus.
- [Coq-Club] Symmetry does not work with <>, Marcus Ramos, 07/22/2014
- Re: [Coq-Club] Symmetry does not work with <>, Jonathan, 07/22/2014
- Re: [Coq-Club] Symmetry does not work with <>, Marcus Ramos, 07/22/2014
- Re: [Coq-Club] Symmetry does not work with <>, gallais, 07/23/2014
- Re: [Coq-Club] Symmetry does not work with <>, Marcus Ramos, 07/28/2014
