coq-club - [Coq-Club] Local Canonical Structures instances
  • To: coq-club <coq-club AT inria.fr>
  • Subject: [Coq-Club] Local Canonical Structures instances
  • Date: Mon, 28 Jul 2014 23:48:07 +0100
Hi,
Is it possible to make a canonical structure instance local?  I can't use the [Local] prefix, as I get the error "Error: This command does not support the "Local" prefix.".  However, I want to trigger the instance that I have when a projection matches a section variable, and if I leave the instance in, I get unrelated canonical structure failures (and the occasional anomaly), such as the following:
Structure foo := { bar : Type; baz : bar }.
Canonical Structure foon := {| bar := nat ; baz := 0 |}.
Definition qux := nat.
Definition z : qux := 0.
Check (eq_refl : baz _ = z).
Section x.
  Variable b : Type.
  Variable p : b.
  Canonical Structure local_foo (bad : False) := {| bar := b ; baz := p |}.
End x.
Goal True.
pose (eq_refl : baz _ = z). (* Error: Cannot infer an internal placeholder of type "False". *)
Thanks,
Jason
  • [Coq-Club] Local Canonical Structures instances, Jason Gross, 07/29/2014
