coq-club - Re: [Coq-Club] making evars easier to solve
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] making evars easier to solve
  • Date: Thu, 31 Jul 2014 11:10:11 -0400
On 07/29/2014 05:10 PM, Jonathan wrote:
Coming up with one that will work in all cases is turning out to be quite difficult.
It wasn't that difficult - skolemize_evars just needed some slight modifications:
Ltac dep_skolemize_evars :=
repeat
match goal with
H := ?V : ?T, H' : ?T' |- _ =>
match goal with
| H2 := ?V2 : _ |- _ => has_evar V2; match H2 with H' => fail 2 end
| _ => idtac
end;
match V with
context[?eV] =>
is_evar eV;
match V with
| context[H'] => fail 1
| _ => idtac
end;
match type of H' with
(?W') =>
match type of eV with
?VT =>
let f:=fresh in
let x:=(eval pattern H' in VT) in
match x with
?x' _ =>
evar (f:forall (a:W'), x' a); unify eV (f H'); subst f
end
end
end
end
end.
This seems to work at least in the very few cases I've tried so far. The Ltac is ugly, and probably highly inefficient in goals with many hypotheses, but most of that is due to not being able to use certain Ltac idioms (like reverting hypotheses while iterating over them) that due to Coq's conservative ways would alter the instantiatability of the very evars we're trying to "save".
It also certainly does produce redundant proofs, as one ends up needing to instantiate the skolem function with things like match expressions that recapitulate some of the proof steps between skolemization and eventual instantiation. At least you no longer need to know what the correct instantiation is a-priori.
After using it a bit, it just makes me wonder what it would take to get Coq to be less conservative with its evar instantiation rules - because skolemization is doing so little to accomplish a workaround to these rules, but that workaround ends up having a price.
-- Jonathan
