- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] making evars easier to solve
- Date: Tue, 29 Jul 2014 17:10:57 -0400
Here's a first attempt at a skolemizing tactic. I think it will only work for non-dependent hypotheses, though. Coming up with one that will work in all cases is turning out to be quite difficult.
[the following was only tested in the trunk version, not in 8.4]
Ltac name_evars id :=
repeat match goal with |- context[?V] => is_evar V; let H := fresh id in set (H:=V) in * end.
Ltac skolemize_evars :=
repeat
match goal with
H := ?V : ?T, H' : ?T' |- _ =>
match goal with
| H2 := ?V2 : _ |- _ => has_evar V2; match H2 with H' => fail 2 end
| _ => idtac
end;
match V with
context[?eV] =>
is_evar eV;
match V with
| context[H'] => fail 1
| _ => idtac
end;
match type of H' with
(?W') =>
match type of eV with
?VT =>
let f:=fresh in
evar (f:W'->VT); unify eV (f H'); subst f
end
end
end
end.
Goal forall (n : nat)(b : bool)(f : nat->bool)(P: bool->bool->Prop),
exists b' n', P (f n') b <-> P b' (f n).
intros i j f P.
do 2 eexists.
name_evars e.
skolemize_evars.
Abort.
-- Jonathan
- [Coq-Club] making evars easier to solve, Jonathan, 07/26/2014
- Re: [Coq-Club] making evars easier to solve, Gregory Malecha, 07/27/2014
- Re: [Coq-Club] making evars easier to solve, Jonathan, 07/27/2014
- Re: [Coq-Club] making evars easier to solve, Gregory Malecha, 07/28/2014
- Re: [Coq-Club] making evars easier to solve, Jonathan, 07/28/2014
- Re: [Coq-Club] making evars easier to solve, Jonathan, 07/29/2014
- Re: [Coq-Club] making evars easier to solve, Jonathan, 07/31/2014
