- From: Pierre-Marie Pédrot <pierre-marie.pedrot AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Running a tactic to get a constr
- Date: Fri, 01 Aug 2014 17:12:05 +0200
On 01/08/2014 17:06, Jason Gross wrote:
> Is there any way to run a tactic to get a constr? That is, say I have a
> tac [t] which, when run, either returns a [constr], or does [fail
> <message>]. Is there any way to, in the enclosing tactic, say "run u on
> the constr returned by t if it returns a constr, and otherwise fail with
> the same message as t"?
The usual trick to do this is to use a CPS version of the tactic:
instead of returning the constr, you pass it to a continuation k. In
your case, you get something along the lines of:
let t k := lazymatch goal with
| [ |- True ] => let ans := constr:(1) in k ans
| [ |- False ] => fail "Found False"
end in ...
There are some uses of this trick in the standard library, for instance
in the ring tactic if I remember well. Yet, if you don't have access to
the body of the tactic, I do not know if this is doable at all...
PMP
signature.asc
Description: OpenPGP digital signature
- [Coq-Club] Running a tactic to get a constr, Jason Gross, 08/01/2014
- Re: [Coq-Club] Running a tactic to get a constr, Pierre-Marie Pédrot, 08/01/2014
