coq-club - [Coq-Club] Running a tactic to get a constr
  • To: coq-club <coq-club AT inria.fr>
  • Subject: [Coq-Club] Running a tactic to get a constr
  • Date: Fri, 1 Aug 2014 16:06:16 +0100
Hi,
Is there any way to run a tactic to get a constr?  That is, say I have a tac [t] which, when run, either returns a [constr], or does [fail <message>].  Is there any way to, in the enclosing tactic, say "run u on the constr returned by t if it returns a constr, and otherwise fail with the same message as t"?  That happens, for example, if you do
let t := lazymatch goal with
             | [ |- True ] => constr:(1)
             | [ |- False ] => fail "Found False"
           end in
The closest I've managed to come is
             | [ |- False ] => fail 1 "Found False"
           end in
let t' := match True with
             | _ => t
           end in
But I can't do this if I don't have access to the source of the tactic that fails in the lazymatch, and can't bump up the failure level from 0 to 1.
Thanks,
Jason
