- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Designing [info] again
- Date: Tue, 05 Aug 2014 08:46:07 -0400
For my purposes, a top-level command
would be just as good. Likewise for [debug], BTW.
On 08/05/2014 05:12 AM, Arnaud Spiwack wrote: Another question: is it useful that [info] be a
tactic? Or can it be a toplevel command?
If it is useful as a tactic, what should something like [info (t;info u)] print? On 25 July 2014 16:28, Jonathan <jonikelee AT gmail.com>
wrote:
On 07/25/2014 06:32 AM, Arnaud Spiwack wrote:
Dear all,
- What do you use [info] for?I'm currently working on polishing my part for the upcoming version of Coq. One common request I got was to bring back the [info] tactical. And, as it happens, I'm now in a situation where I can make it happen. But what I cannot do, is take the code for the old [info] and port it to the current development version, I really have do write the feature from scratch. And if I get to do [info] anew, I really want to get it right (and possibly divide it in several features). So, dear [info] user, I'm asking you: - Do you use the [info (info t)] feature? - If you had one or two feature request for [info] to make it even slightly better, what would they be? you really wished you had in your toolbox? /Arnaud Spiwack I have some experience with PVS (a long time ago), which has a feature allowing one to see what any non-atomic tactic was doing by causing that tactic to print out the successful part of its internal script - as an actual script. That was very helpful for learning the tactic language (which I no longer recall). I vaguely recall that it was also possible to capture the spilled low-level tactic script as a replacement for the high-level tactic - allowing one to shortcut the automation when replaying in favor of the direct script (and get a performance boost as a result due to eliminating all of the failed search paths). Or, maybe that's a false memory of how I wanted it to work. But, I also think that there needs to be a better way to debug a complicated tactic than the current Ltac debugger - and having a way to trace all of the workings of the tactic (even the failures and backtracks) would help there. And, for really big proof searches, there should be a way to filter that trace. |
- Re: [Coq-Club] Designing [info] again, Arnaud Spiwack, 08/05/2014
- Re: [Coq-Club] Designing [info] again, Adam Chlipala, 08/05/2014
- Re: [Coq-Club] Designing [info] again, Jonathan, 08/05/2014
