coq-club - Re: [Coq-Club] Designing [info] again
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Designing [info] again
  • Date: Tue, 05 Aug 2014 13:19:53 -0400
On 08/05/2014 05:12 AM, Arnaud Spiwack wrote:
Another question: is it useful that [info] be a tactic? Or can it be a
toplevel command?
If it is useful as a tactic, what should something like [info (t;info u)]
print?
That depends on what it will do. If, like the version in PVS (which I think just required prefixing a tactic with "@"), it causes the recorded script to record the successful low-level tactics instead of the single info'ed high-level one, then wouldn't it be beneficial in cases that currently use abstract, or maybe in addition to abstract?
If, on the other hand, it just prints things out, then I don't see as much benefit to making it a tactic vs. a top-level command. But it might be helpful when debugging a complex tactic to just info certain internal components instead of the whole thing. In that case, [info (t;info u)] could act just like [info (t;u)].
-- Jonathan
