- From: "Soegtrop, Michael" <michael.soegtrop AT intel.com>
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: RE: [Coq-Club] Hints needed for two SF exercises
- Date: Wed, 20 Aug 2014 11:14:22 +0000
- Accept-language: de-DE, en-US
Dear John,
instead of an inductive proof, you can make a "recursive proof", that is
define a fixpoint which takes an argument of type l = rev l and returns pal X
l.
You can use tactics to create the function body. The syntax looks like this:
Fixpoint rev_pal' X (l : list X) (h : l = rev l) : pal X l.
Proof.
Use rev_pal' in the proof
Qed.
It is still quite tricky, though. To convince Coq that this terminates, I had
to add the list length as parameter.
Best regards,
Michael
-----Original Message-----
[mailto:jwiegley AT gmail.com]
On Behalf Of John Wiegley
Sent: Wednesday, August 20, 2014 12:07 PM
To:
Subject: [Coq-Club] Hints needed for two SF exercises
Hello,
There are two exercises in Software Foundations that have me stumped at the
moment. The first is "rev_pal" from Prop.v. Is there a way to solve this
more simply than defining a new induction principle for lists that looks at
both ends? If so, a hint would be lovely. If not, knowing that I must go
that route is also appreciated.
The second is "pigeonhole_principle". With or without LEM I run into the same
problem: a goal of n < m in a context of n < S m, which is clearly unprovable.
If induction on l1 is the right way to start this proof, what is the next
creative step? So far I have:
Theorem pigeonhole_principle: forall (X:Type) (l1 l2:list X),
(forall x, appears_in x l1 -> appears_in x l2)
-> length l2 < length l1
-> repeats l1.
Proof.
move=> X.
elim=> [|x xs IHxs] l2 Happ Hlen.
inversion Hlen.
apply repeats_tail.
apply: IHxs => // [z ?|].
apply: Happ. by constructor.
Admitted.
I'm missing information about the 'x' it seems. I can imagine two scenarios:
l1: [1,2,3,1] l2: [1,2,3]
l1: [2,1,3,1] l2: [2,1,3]
My attempt lacks knowledge about whether 'x' is a repeating element, which
would determine the constructor to use, and thus give me the knowledge that
should make the remainder provable. But how? Even with LEM I get stuck in
the same spot, so a clue on solving it that way would also be helpful.
Thanks,
John
- [Coq-Club] Hints needed for two SF exercises, John Wiegley, 08/20/2014
- Re: [Coq-Club] Hints needed for two SF exercises, Ilya Sergey, 08/20/2014
- RE: [Coq-Club] Hints needed for two SF exercises, Soegtrop, Michael, 08/20/2014
- Re: [Coq-Club] Hints needed for two SF exercises, John Wiegley, 08/20/2014
- Re: [Coq-Club] Hints needed for two SF exercises, Daniel Schepler, 08/20/2014
- Re: [Coq-Club] Hints needed for two SF exercises, Basile Clement, 08/20/2014
- Re: [Coq-Club] Hints needed for two SF exercises, Xavier Leroy, 08/21/2014
- Re: [Coq-Club] Hints needed for two SF exercises, John Wiegley, 08/22/2014
- Re: [Coq-Club] Hints needed for two SF exercises, Daniel Schepler, 08/22/2014
