coq-club - Re: [Coq-Club] Hints needed for two SF exercises
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Hints needed for two SF exercises
  • Date: Wed, 20 Aug 2014 18:43:48 +0200
On 08/20/2014 12:07 PM, John Wiegley wrote:
Hello,
There are two exercises in Software Foundations that have me stumped at the
moment. The first is "rev_pal" from Prop.v. Is there a way to solve this
more simply than defining a new induction principle for lists that looks at
both ends? If so, a hint would be lovely. If not, knowing that I must go
that route is also appreciated.
Instead of writing your own induction principle, you can use the list's length and first prove
forall (X:Type) (n:nat) (l:list X), length l <= n -> l = rev l -> pal l
This can be proven quite easily by induction on [n], although it is only simpler in the sense that the natural numbers and a couple of theorems on the [length] function have already been proven.
The second is "pigeonhole_principle". With or without LEM I run into the same
problem: a goal of n < m in a context of n < S m, which is clearly unprovable.
If induction on l1 is the right way to start this proof, what is the next
creative step? So far I have:
Theorem pigeonhole_principle: forall (X:Type) (l1 l2:list X),
(forall x, appears_in x l1 -> appears_in x l2)
-> length l2 < length l1
-> repeats l1.
Proof.
move=> X.
elim=> [|x xs IHxs] l2 Happ Hlen.
inversion Hlen.
apply repeats_tail.
apply: IHxs => // [z ?|].
apply: Happ. by constructor.
Admitted.
I'm missing information about the 'x' it seems. I can imagine two scenarios:
l1: [1,2,3,1] l2: [1,2,3]
l1: [2,1,3,1] l2: [2,1,3]
My attempt lacks knowledge about whether 'x' is a repeating element, which
would determine the constructor to use, and thus give me the knowledge that
should make the remainder provable. But how? Even with LEM I get stuck in
the same spot, so a clue on solving it that way would also be helpful.
Thanks,
John
Basile
