- From: Matthieu Sozeau <matthieu.sozeau AT gmail.com>
- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Beginner typeclass question
- Date: Thu, 28 Aug 2014 09:25:52 +0200
On 26 août 2014, at 19:08, Kevin Sullivan
<sullivan.kevinj AT gmail.com>
wrote:
> I'm trying to use typeclass inheritance (using :>) to model a
> specialization hierarchy in which subclasses provide values for certain
> fields that are declared but left abstract in a superclass. This seems not
> possible. Can someone (a) confirm, and (b) suggest an alternative design
> pattern.
> The problem: it appears that a super-typeclass has to be fully instantiated
> before one can instantiate a subclass, but values defined in a subclass are
> unavailable until the subclass is instantiated -- catch 22.
> In a little more detail, I want to provide an implementation, in a
> subclass, of a function that is declared but not defined in a type
> superclass. The implementation is defined in terms of other functions
> introduced in the subclass.
Hi Kevin,
I don’t think I’ve seen this pattern yet and indeed it seems it can’t work
in the current system the way
you describe it. I can only think of using propositional equalities to do
that:
Class SubClass A := { sup : SuperClass A; …; spec : fn sup = bar }
Best,
— Matthieu
- [Coq-Club] Beginner typeclass question, Kevin Sullivan, 08/26/2014
- Re: [Coq-Club] Beginner typeclass question, Matthieu Sozeau, 08/28/2014
