- From: Kevin Sullivan <sullivan.kevinj AT gmail.com>
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: [Coq-Club] Beginner typeclass question
- Date: Tue, 26 Aug 2014 13:08:16 -0400
I'm trying to use typeclass inheritance (using :>) to model a specialization hierarchy in which subclasses provide values for certain fields that are declared but left abstract in a superclass. This seems not possible. Can someone (a) confirm, and (b) suggest an alternative design pattern.
The problem: it appears that a super-typeclass has to be fully instantiated before one can instantiate a subclass, but values defined in a subclass are unavailable until the subclass is instantiated -- catch 22.
In a little more detail, I want to provide an implementation, in a subclass, of a function that is declared but not defined in a type superclass. The implementation is defined in terms of other functions introduced in the subclass.
Kevin
- [Coq-Club] Beginner typeclass question, Kevin Sullivan, 08/26/2014
- Re: [Coq-Club] Beginner typeclass question, Matthieu Sozeau, 08/28/2014
