- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] shelve_unifiable question
- Date: Thu, 04 Sep 2014 09:45:35 -0400
On 09/04/2014 08:50 AM, Arnaud Spiwack wrote:
When using all:shelve_unifiable, is it always supposed to shelve allSaid like that, it sounds like a bug. Can you provide me with a concrete
focused goals that correspond to evars in other focused goals?
It seems like all:shelve_unifiable doesn't shelve a dependent evar goal if
it was modified (as by renaming a hypothesis within it, or case analyzing a
hypothesis within it, or adding a new hypothesis to it, etc.), even though
it still corresponds to an evar in other focused goal(s).
example of this behaviour?
Goal forall a b:nat, exists c:nat, c=a+b.
intros a b.
refine (ex_intro _ _ _).
all:rename a into a'. (*works without this line*)
all:shelve_unifiable.
-- Jonathan
- Re: [Coq-Club] shelve_unifiable question, Arnaud Spiwack, 09/04/2014
- Re: [Coq-Club] shelve_unifiable question, Jonathan, 09/04/2014
