- To: Coq Club <coq-club AT inria.fr>
- Subject: [Coq-Club] suggestion: Lock Existential Dependent Hypotheses, and evar bugs?
- Date: Tue, 09 Sep 2014 13:19:56 -0400
After more experimentation with the evar dependent subgoals (via refine) feature in the trunk...
I noticed that when a hypothesis in one subgoal with evars is modified as by a rewrite .. in hyp or apply .. in hyp, such that instance lists (via Set Printing Existential Instances) mention that hypothesis, the hypothesis is removed from the corresponding evar subgoals (and obviously also the instance lists). This makes some sense, as Coq would otherwise need to know how to reverse that modification to create an adequate substitution (in the case of a rewrite-in that is often possible, but not an apply-in). But it is surprising, and unfortunately could lead to an inability to solve those evars later.
Since I have no documentation on the evar dependent subgoals feature (is there any?), this might be a bug or just a temporary measure that isn't the eventual desired behavior. Assuming however that it is the desired behavior: in order to prevent proof automation from accidentally making such modifications to hypotheses (without making the identical modifications in the evar subgoals themselves), how about adding a command like Set Lock Existential Dependent Hypotheses - which would then cause Coq to fail in such cases - similarly to how it currently fails if an attempt is made to alter a hypotheses on which another in the same subgoal (or the consequent) depends (at least for non-"dependent" variations of tactics)?
Example:
Set Printing Existential Instances. (*or View->Display existential variable instances*)
Goal forall a b:nat, a=b -> exists c:nat, c>a.
intros a b H.
refine (ex_intro _ _ _).
all:cycle 1.
apply eq_sym in H. (*removes H from evar subgoal and instances*)
With the requested Set Lock Existential Dependent Hypotheses turned on, that last apply would fail (unless it was applied in the evar subgoal as well).
Oh - that points out some bugs. If you instead do "all:apply eq_sym in H", it fails with "Error: No such hypothesis: H" - even though H exists in both subgoals. And if you try the "all:apply eq_sym in H" without first doing "all:cycle 1", it also fails, but this time with "Error: Cannot change H, it is used in conclusion." - even though H is not used in the conclusion.
Should I report these, or are evar dependent subgoals under active development and the above are just temporary behaviors?
-- Jonathan
- [Coq-Club] suggestion: Lock Existential Dependent Hypotheses, and evar bugs?, Jonathan, 09/09/2014
- Re: [Coq-Club] suggestion: Lock Existential Dependent Hypotheses, and evar bugs?, Jonathan, 09/10/2014
