Re: [Coq-Club] suggestion: Lock Existential Dependent Hypotheses, and evar bugs?
- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] suggestion: Lock Existential Dependent Hypotheses, and evar bugs?
- Date: Wed, 10 Sep 2014 12:36:28 -0400
On 09/09/2014 01:19 PM, Jonathan wrote:
Example:
Set Printing Existential Instances. (*or View->Display existential variable instances*)
Goal forall a b:nat, a=b -> exists c:nat, c>a.
intros a b H.
refine (ex_intro _ _ _).
all:cycle 1.
apply eq_sym in H. (*removes H from evar subgoal and instances*)
With the requested Set Lock Existential Dependent Hypotheses turned on, that last apply would fail (unless it was applied in the evar subgoal as well).
Oh - that points out some bugs. If you instead do "all:apply eq_sym in H", it fails with "Error: No such hypothesis: H" - even though H exists in both subgoals. And if you try the "all:apply eq_sym in H" without first doing "all:cycle 1", it also fails, but this time with "Error: Cannot change H, it is used in conclusion." - even though H is not used in the conclusion.
The confusion in the error messages is really not that confusing after realizing that by using "all:", the apply tactic is sequentially applied to each focused subgoal in order. With that in mind, the first "Error: No such hypothesis: H" is due to H being removed from the second subgoal by the apply in the first - as the example demonstrates. The second "Error: Cannot change H, it is used in conclusion" is because applying eq_sym in H in the evar subgoal correspondingly alters the evar instantiation in the first such that H does appear in its conclusion. So, these are not bugs.
Still, having the ability to lock down hypotheses like H due to the evar dependencies would be nice...
-- Jonathan
- [Coq-Club] suggestion: Lock Existential Dependent Hypotheses, and evar bugs?, Jonathan, 09/09/2014
- Re: [Coq-Club] suggestion: Lock Existential Dependent Hypotheses, and evar bugs?, Jonathan, 09/10/2014
