- From: Pierre Courtieu <pierre.courtieu AT gmail.com>
- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Recurrent sequence and unrecurrent formula
- Date: Thu, 2 Oct 2014 18:08:07 +0200
Here is an attempt but I reach something wrong. Are you sure about
this statement?
Require Import Ring.
Require Import Arith.
Inductive w: nat -> nat -> Prop :=
| C0: w 0 1
| CS : forall n x y, w n y -> n*x = (S n)*y+1 -> w (S n) x.
Lemma foo: forall n, w n (2 * n + 1).
Proof.
induction n.
- constructor.
- simpl in *.
eapply CS.
apply IHn.
ring_simplify.
(* wrong *)
2014-10-02 17:35 GMT+02:00 Christophe Bal
<projetmbc AT gmail.com>:
> Hello.
> Sorry for this very low level question (I still not found the time to learn
> seriously Coq).
> Let's consider the sequence defined by n w_n = (n + 1)w_{n-1} + 1 with the
> initial condition w_0 = 1 .
> How can I verify the validity of w_n = 2 n + 1 ?
> Christophe
- [Coq-Club] Recurrent sequence and unrecurrent formula, Christophe Bal, 10/02/2014
- Re: [Coq-Club] Recurrent sequence and unrecurrent formula, Pierre Courtieu, 10/02/2014
- Re: [Coq-Club] Recurrent sequence and unrecurrent formula, Ilmārs Cīrulis, 10/02/2014
- Re: [Coq-Club] Recurrent sequence and unrecurrent formula, Cedric Auger, 10/02/2014
- Re: [Coq-Club] Recurrent sequence and unrecurrent formula, Christophe Bal, 10/02/2014
- Re: [Coq-Club] Recurrent sequence and unrecurrent formula, Frederic Chyzak, 10/03/2014
