- From: Pierre Courtieu <pierre.courtieu AT gmail.com>
- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Recurrent sequence and unrecurrent formula
- Date: Thu, 2 Oct 2014 21:09:55 +0200
2014-10-02 18:30 GMT+02:00 Cedric Auger
<sedrikov AT gmail.com>:
> You got tricked with indice, Pierre. The correct form is the following one:
Ops indeed I was tricked.
To cover all the mathematical content from the sequence, you should
probably also prove a unicity result on the sequence: forall n x y, w
n x -> w n y -> x = y.
Best regards
P.
- [Coq-Club] Recurrent sequence and unrecurrent formula, Christophe Bal, 10/02/2014
- Re: [Coq-Club] Recurrent sequence and unrecurrent formula, Pierre Courtieu, 10/02/2014
- Re: [Coq-Club] Recurrent sequence and unrecurrent formula, Ilmārs Cīrulis, 10/02/2014
- Re: [Coq-Club] Recurrent sequence and unrecurrent formula, Cedric Auger, 10/02/2014
- Re: [Coq-Club] Recurrent sequence and unrecurrent formula, Christophe Bal, 10/02/2014
- Re: [Coq-Club] Recurrent sequence and unrecurrent formula, Frederic Chyzak, 10/03/2014
