- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Why can Records not be recursive?
- Date: Thu, 2 Oct 2014 14:19:37 -0400
Thanks.
I seem to recall hearing somewhere that in 8.5 records were getting some ability to elide parameters, though maybe this is just in projections.
On Thu, Oct 2, 2014 at 12:49 PM, Arnaud Spiwack <aspiwack AT lix.polytechnique.fr> wrote:
Record *can* be recursive. It's just that you cannot use the "Record" keyword to that effect (so that you can choose between inductive records and co-inductive records). They cannot appear in mutually inductive type definitions, however, because nobody has managed to make that work properly (but I don't think there is any theoretical issue here). The "Record" keyword is intended for non-recursive records (in trunk, the induction principle is not generated when you use the "Record" keyword, I've also added a dual "Variant" for non-recursive variant types).
Let me print the error message that Coq v8.4 prints when you try to write an inductive record:Error: Records declared with the keyword Record or Structure cannot be recursive. You can, however, define recursive records using the Inductive or CoInductive command.
I don't know how I could have been much clearer. Maybe the reference manual needs updating (though I may have done some improvement in trunk already, I don't remember). If so, let me know what is confusing.CoInductive Stream (A:Type) := {
head : A;
tail : Stream A
(* Stream is defined
head is defined
tail is defined *)
/ArnaudOn 2 October 2014 17:15, Cedric Auger <sedrikov AT gmail.com> wrote:I have complained many times on the fact that records are not allowed to be recursive.
I even tried many times to patch Coq my self to have this feature, but each time I gave up because it was affecting stuff I did not want to modify in the code.
I do not remember the details, but that Coq type classes are implemented over Records for instance. Furthermore the pieces of code I tried to modify relied heavily on type inference, and my brain was not powerfull enough to understand what the underlying types were.You might be interested by this feature request:
https://coq.inria.fr/bugs/show_bug.cgi?id=2779
I guess that one of the initial arguments against such a feature is that a recursive record is not well founded (well in fact, it is not the case, but it is easy to be tricked).
Counter examples are:
Mutual induction:
Record list_header(A : Type): Type :=
{ head : A;
tail : list A }
with list(A : Type): Type :=
| Nil : list A
| Cons : list_header A -> list A.
Accessibility predicate:
Record Acc(T:Type)(P:T->T->Prop): T->Prop :=
fun (t:T) => { Rec: forall u, P u t -> Acc T P u }.--2014-10-02 16:46 GMT+02:00 Gregory Malecha <gmalecha AT cs.harvard.edu>:Hi --Is the a theoretical reason why records can not be recursive? My understanding has always been that [Record] is just syntactic sugar for [Inductive] which generates some extra projection functions. I know that this will change in Coq 8.5 and records will become a new primitive, so will there become a reason why they can't be recursive?
.../Sedrikov\...
gregory malecha
- [Coq-Club] Why can Records not be recursive?, Gregory Malecha, 10/02/2014
- Re: [Coq-Club] Why can Records not be recursive?, Cedric Auger, 10/02/2014
- Re: [Coq-Club] Why can Records not be recursive?, Arnaud Spiwack, 10/02/2014
- Re: [Coq-Club] Why can Records not be recursive?, Gregory Malecha, 10/02/2014
- Re: [Coq-Club] Why can Records not be recursive?, Jason Gross, 10/02/2014
