- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Why can Records not be recursive?
- Date: Thu, 2 Oct 2014 14:23:10 -0400
Yes, Matthieu Sozeau has added the option to make records primitive, which gives them judgmental eta and projections that don't (need to) take any of the arguments of the record type. I don't know if this is enabled for coinductive types or for recursive types.
On Thu, Oct 2, 2014 at 2:19 PM, Gregory Malecha <gmalecha AT cs.harvard.edu> wrote:
Thanks.I seem to recall hearing somewhere that in 8.5 records were getting some ability to elide parameters, though maybe this is just in projections.On Thu, Oct 2, 2014 at 12:49 PM, Arnaud Spiwack <aspiwack AT lix.polytechnique.fr> wrote:Record *can* be recursive. It's just that you cannot use the "Record" keyword to that effect (so that you can choose between inductive records and co-inductive records). They cannot appear in mutually inductive type definitions, however, because nobody has managed to make that work properly (but I don't think there is any theoretical issue here). The "Record" keyword is intended for non-recursive records (in trunk, the induction principle is not generated when you use the "Record" keyword, I've also added a dual "Variant" for non-recursive variant types).
Let me print the error message that Coq v8.4 prints when you try to write an inductive record:Error: Records declared with the keyword Record or Structure cannot be recursive. You can, however, define recursive records using the Inductive or CoInductive command.
I don't know how I could have been much clearer. Maybe the reference manual needs updating (though I may have done some improvement in trunk already, I don't remember). If so, let me know what is confusing.CoInductive Stream (A:Type) := {
head : A;
tail : Stream A
(* Stream is defined
head is defined
tail is defined *)
/ArnaudOn 2 October 2014 17:15, Cedric Auger <sedrikov AT gmail.com> wrote:I have complained many times on the fact that records are not allowed to be recursive.
I even tried many times to patch Coq my self to have this feature, but each time I gave up because it was affecting stuff I did not want to modify in the code.
I do not remember the details, but that Coq type classes are implemented over Records for instance. Furthermore the pieces of code I tried to modify relied heavily on type inference, and my brain was not powerfull enough to understand what the underlying types were.You might be interested by this feature request:
https://coq.inria.fr/bugs/show_bug.cgi?id=2779
I guess that one of the initial arguments against such a feature is that a recursive record is not well founded (well in fact, it is not the case, but it is easy to be tricked).
Counter examples are:
Mutual induction:
Record list_header(A : Type): Type :=
{ head : A;
tail : list A }
with list(A : Type): Type :=
| Nil : list A
| Cons : list_header A -> list A.
Accessibility predicate:
Record Acc(T:Type)(P:T->T->Prop): T->Prop :=
fun (t:T) => { Rec: forall u, P u t -> Acc T P u }.--2014-10-02 16:46 GMT+02:00 Gregory Malecha <gmalecha AT cs.harvard.edu>:Hi --Is the a theoretical reason why records can not be recursive? My understanding has always been that [Record] is just syntactic sugar for [Inductive] which generates some extra projection functions. I know that this will change in Coq 8.5 and records will become a new primitive, so will there become a reason why they can't be recursive?
.../Sedrikov\...--gregory malecha
- [Coq-Club] Why can Records not be recursive?, Gregory Malecha, 10/02/2014
- Re: [Coq-Club] Why can Records not be recursive?, Cedric Auger, 10/02/2014
- Re: [Coq-Club] Why can Records not be recursive?, Arnaud Spiwack, 10/02/2014
- Re: [Coq-Club] Why can Records not be recursive?, Gregory Malecha, 10/02/2014
- Re: [Coq-Club] Why can Records not be recursive?, Jason Gross, 10/02/2014
