- From: Pierre Boutillier <pierre.boutillier AT pps.univ-paris-diderot.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Where to put contribs as non-root
- Date: Mon, 6 Oct 2014 18:28:12 +0200
The idea of Tom Prince has been implemented and
make userinstall
should do the work. Complain on coq.inria.fr/bugs/ if it does not :-)
Pierre B.
PS : OK I realize that I checked in trunk. I’m pretty sure it is older than
8.4 but I’m sorry if it isn’t ...
Le 6 oct. 2014 à 18:20, Robbert Krebbers
<mailinglists AT robbertkrebbers.nl>
a écrit :
> Hello,
> I am trying to compile a Coq project that relies on ssreflect and mathcomp.
> While doing this, I wonder if one does not want to
> make install
> due to the lack of superuser rights (or because one wants to keep Coq
> contribs in a place that is user writable), what is the appropriate place
> to put user contributions?
> On the mailinglist, I can only find a discussion on "04/24/2011 04:18 PM"
> where Tom Prince proposes to use "$HOME/.local/lib/coq" for this. What is
> the current status?
> Robbert
- [Coq-Club] Where to put contribs as non-root, Robbert Krebbers, 10/06/2014
- Re: [Coq-Club] Where to put contribs as non-root, Pierre Boutillier, 10/06/2014
- Re: [Coq-Club] Where to put contribs as non-root, Robbert Krebbers, 10/06/2014
- Re: [Coq-Club] Where to put contribs as non-root, Vincent Laporte, 10/06/2014
