coq-club - Re: [Coq-Club] Where to put contribs as non-root
  • From: Vincent Laporte <vincent.laporte AT gmail.com>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Where to put contribs as non-root
  • Date: Mon, 06 Oct 2014 17:51:49 +0100
Hello,
You may install libraries wherever is convenient for you. Then make sure
to set the $COQPATH environment variable accordingly.
For instance, if you install ssreflect using:
make install COQLIB=/your/path/
then if you add `/your/path/user-contrib` to the $COQPATH environment
variable, coqtop / coqc / coqide will find ssreflect:
export COQPATH=/your/path/user-contrib:$COQPATH
Regards,
Vincent.
