- To: coq-club <coq-club AT inria.fr>
- Subject: [Coq-Club] Induction principle for Fix?
- Date: Wed, 15 Oct 2014 22:09:49 -0400
Hi,
Is there a variant of Coq.Init.Fix_eq that allows you to prove properties about [Fix]es by well-founded induction? That is, say that I have [Q : forall x, P x -> Type], and my goal is [Q x (@Fix A R Rwf P F x)]. If I do [rewrite Coq.Init.Fix_eq], I can then progress on my goal to the point where I am again faced with something like [Q y (@Fix A R Rwf P F y)]. Is there an induction principle for [Fix] that I can use to prove my goal? Intuitively, as long as the function has [Acc] fuel for recursing, I can use the same fuel to keep rewriting with [Fix_eq].
Thanks,
Jason
- [Coq-Club] Induction principle for Fix?, Jason Gross, 10/16/2014
- Re: [Coq-Club] Induction principle for Fix?, Cedric Auger, 10/16/2014
- Re: [Coq-Club] Induction principle for Fix?, Jason Gross, 10/16/2014
- <Possible follow-up(s)>
- Re: [Coq-Club] Induction principle for Fix?, julien . forest, 10/16/2014
