- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Induction principle for Fix?
- Date: Thu, 16 Oct 2014 16:31:04 -0400
Indeed, I can prove:
Definition Fix_rect
A (R : A -> A -> Prop) (Rwf : well_founded R)
(P : A -> Type) (F : forall x : A, (forall y : A, R y x -> P y) -> P x)
(Q : forall x, P x -> Type)
(H : forall x, (forall y, R y x -> Q y (@Fix A R Rwf P F y)) -> Q x (@F x (fun (y : A) (_ : R y x) => @Fix A R Rwf P F y)))
(F_ext : forall (x : A) (f g : forall y : A, R y x -> P y),
(forall (y : A) (p : R y x), f y p = g y p) -> F _ f = F _ g).
x
: @Q x (@Fix A R Rwf P F x).
Proof.
induction (Rwf x).
rewrite Init.Wf.Fix_eq; auto.
Defined.
Thanks,
Jason
On Thu, Oct 16, 2014 at 5:29 AM, Cedric Auger <sedrikov AT gmail.com> wrote:
As I am not used to Coq.Init.Fix_eq, I do not fully understand the question, but if you can prove something like "AccRx : Acc R x" then if you start your proof with "induction AccRx." then you should have to prove that "forall x, (forall y, R x y -> Q x (@Fix A R Rwf P F y)) -> Q x (@Fix A R Rwf P F y)".
From there, you do your "intros x Hx", and your rewrite Coq.Init.Fix_eq to go to the point where you have to face something like "Q y (@Fix A R Rwf P F y)". There you apply Hx, and you only have to prove that you have "R x y", which I guess should be the case.--2014-10-16 4:09 GMT+02:00 Jason Gross <jasongross9 AT gmail.com>:Hi,Is there a variant of Coq.Init.Fix_eq that allows you to prove properties about [Fix]es by well-founded induction? That is, say that I have [Q : forall x, P x -> Type], and my goal is [Q x (@Fix A R Rwf P F x)]. If I do [rewrite Coq.Init.Fix_eq], I can then progress on my goal to the point where I am again faced with something like [Q y (@Fix A R Rwf P F y)]. Is there an induction principle for [Fix] that I can use to prove my goal? Intuitively, as long as the function has [Acc] fuel for recursing, I can use the same fuel to keep rewriting with [Fix_eq].Thanks,Jason
.../Sedrikov\...
- [Coq-Club] Induction principle for Fix?, Jason Gross, 10/16/2014
- Re: [Coq-Club] Induction principle for Fix?, Cedric Auger, 10/16/2014
- Re: [Coq-Club] Induction principle for Fix?, Jason Gross, 10/16/2014
- <Possible follow-up(s)>
- Re: [Coq-Club] Induction principle for Fix?, julien . forest, 10/16/2014
