coq-club - Re: [Coq-Club] Annotation for Dependent Pattern Matching
  • From: Gabriel Scherer <gabriel.scherer AT gmail.com>
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Annotation for Dependent Pattern Matching
  • Date: Sat, 1 Nov 2014 13:17:44 +0100
I don't have any intuition about your distinction between valid and
invalid, and the structure of is_valid. The valid_cons function looks
like it is trying to translate a term in AllCons into a term that does
not use the constructors you call "valid", but is actually defined
only on terms that have valid constructors at the top-level (what
about (all_or all_zero all_zero) for example?).
You say that valid_cons ought to translate valid constructors into
"non-valid" ones, but was is a non-valid constructor? If it was only
the negation of the "valid" predicate, you would not need to call
valid_cons recursively for this result to hold: (all_or A B) is not
valid, regardless of what A and B are. It seems there is an underlying
notion of "not valid" that is somehow "recursively not a valid
constructor" -- but this would be weird it means some terms that are
"deeply not valid" in thise sense are not in the "is_valid" relation
and thus cannot be passed to the valid_cons function.
I wrote the following, using a distinction between "simple" and
"derived" constructors (the latter which you call "valid"). The
valid_cons function becomes a function that turns any term into a term
using only simple constructors.
Fixpoint simplify C := match C with
| all_choice A B => all_or (simplify A) (simplify B)
| all_zero => all_unit
| all_or A B => all_or (simplify A) (simplify B)
| all_and A B => all_and (simplify A) (simplify B)
| all_unit => all_unit
end.
Inductive simple : AllCons -> Prop :=
| simple_or : forall a b (AS: simple a) (BS: simple b),
simple (all_or a b)
| simple_and : forall a b (AS: simple a) (BS: simple b),
simple (all_and a b)
| simple_unit : simple all_unit
Lemma simplify_simple : forall C, simple (simplify C).
induction C; simpl; constructor; auto.
Qed.
On Sat, Nov 1, 2014 at 12:34 PM, Craig McLaughlin
<mr_mcl AT live.co.uk>
wrote:
> Hi all,
> I'm trying to define a fixpoint which operates on a subset of an inductive
> type. I've defined a notion of ``valid'' constructors and created a fixpoint
> with a subset type argument using this predicate. The fixpoint converts
> ``valid'' constructors to ``non-valid'' constructors; I have attempted to do
> this using PROGRAM. However, I'm not sure what annotation I should be
> placing
> on my matching construct to get the typechecker to accept it. From the code
> below (Coq v8.4pl4), I get the following error:
> Recursive call to valid_cons has principal argument equal to
> "exist (fun x : AllCons => is_valid x) A ?8" instead of
> a subterm of "C".
> It should be a matter of somehow including the AV and BV assumptions in the
> [valid_choice] case of [is_valid], but I'm not aware of any similar
> examples.
> Require Import Program.
> Set Implicit Arguments.
> Inductive AllCons : Set :=
> (* valid constructors section *)
> | all_choice : AllCons -> AllCons -> AllCons
> | all_zero : AllCons
> (* Other constructors *)
> | all_or : AllCons -> AllCons -> AllCons
> | all_and : AllCons -> AllCons -> AllCons
> | all_unit : AllCons.
> Inductive is_valid : AllCons -> Prop :=
> | valid_choice : forall a b (AV: is_valid a) (BV: is_valid b),
> is_valid (all_choice a b)
> | valid_zero : is_valid all_zero.
> Program Fixpoint valid_cons (C: {x : AllCons | is_valid x}) {struct C} :=
> match C with
> | all_choice A B => all_or (valid_cons A) (valid_cons B)
> | _ => False_rec _ _
> end.
> Regards,
> Craig
