coq-club - Re: [Coq-Club] Annotation for Dependent Pattern Matching
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Annotation for Dependent Pattern Matching
  • Date: Sat, 01 Nov 2014 15:29:11 -0400
On 11/01/2014 02:16 PM, Craig McLaughlin wrote:
Thanks Jonathan! I was hesitant to use the proof mechanism to define functions
for fear that the implementation would be much less efficient than PROGRAM.
However, it seems much easier to define dependently typed functions this way;
in the past I also have tried the [refine] tactic but found it to be awkward
to use for the impossible cases.
Is there much consensus within the Coq community on the most favourable
approach?
I don't know anything about a consensus. Probably the only consensus is: whatever works for you.
But, note that there are several disadvantages to using proofs to define functions. One is that the resulting proof term can be quite unwieldy, and is going to make some proofs about the function - those which have to unfold the function - more difficult (although using Program often creates a similar problem). Another is that a tactic script proof doesn't resemble what most people consider a program, so if you care about the appearance of the script instead of just how it extracts, that might discourage you. Another is that while formulating the proof script, if the goal type isn't sufficiently constrained, then one can easily get confused about how subgoals within the proof correspond to points within the function definition.
But, even if one or more of the above (or something else) is reason enough for you to not use proofs to define functions - if you get stuck, it might help you to try a proof to see how the subgoals proceed during proof interaction, or even what the resulting proof term is (by using Print, or Compute to get some simplification).
Personally, I view the advantages of using proofs to define functions (tactic power with respect to dependent types, incremental interaction with the prover, proof automation and user-defined tactics) to outweigh the disadvantages. I try to arrange things such that the dependent type of functions I define is sufficiently constrained so that I don't need to unfold functions (I view unfolding of non-trivial functions as unmodular anyway) in other proofs, and also don't need to keep precise track of the correspondence between subgoals and points within the function definition. I also do extraction after every non-trivial function definition to make sure the proof did what I wanted.
-- Jonathan
