- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Question about a lemma concerning vectors
- Date: Mon, 10 Nov 2014 03:49:15 -0600
- Organization: New Artisans LLC
>>>>> Cedric Auger
>>>>> <sedrikov AT gmail.com>
>>>>> writes:
> This way dependant types will be less annoying to deal with.
Hi Cedric,
I've moved to the following dependent type:
Definition Vec : nat -> Type :=
fix vec n := match n return Type with
| O => Void
| S O => A
| S n => prod A (vec n)
end.
In general, this has worked out quite well. However, I'm still having
difficulty with one lemma in particular (where fin n is "ordinal n" from
ssreflect):
Lemma vnth_replace_neq : forall n (v : Vec n) (k j : fin n) (z : A),
k != j -> vnth (replace v k z) j = vnth v j.
The problem seems to be that I need to relate three different things in
lock-step: v, k and j. I've tried induction on all three, and also n, but
each direction leaves me with a branch where it asks to prove something that
doesn't make sense.
You can see the code I have so far here, if interested:
https://github.com/jwiegley/linearscan/blob/master/Vector2.v#L209
I also tried building a recursion principle that would walk over the vector at
the same time as its indices, but I'm not sure if this is a worthwhile avenue
to continue pursuing.
Thanks, John
- [Coq-Club] Question about a lemma concerning vectors, John Wiegley, 11/09/2014
- Re: [Coq-Club] Question about a lemma concerning vectors, Cedric Auger, 11/09/2014
- Re: [Coq-Club] Question about a lemma concerning vectors, John Wiegley, 11/09/2014
- Re: [Coq-Club] Question about a lemma concerning vectors, Adam Chlipala, 11/09/2014
- Re: [Coq-Club] Question about a lemma concerning vectors, John Wiegley, 11/10/2014
- Re: [Coq-Club] Question about a lemma concerning vectors, Emilio Jesús Gallego Arias, 11/10/2014
- Re: [Coq-Club] Question about a lemma concerning vectors, Cedric Auger, 11/10/2014
- Re: [Coq-Club] Question about a lemma concerning vectors, John Wiegley, 11/11/2014
- Re: [Coq-Club] Question about a lemma concerning vectors, Emilio Jesús Gallego Arias, 11/09/2014
- Re: [Coq-Club] Question about a lemma concerning vectors, Frédéric Blanqui, 11/12/2014
