- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Question about a lemma concerning vectors
- Date: Mon, 10 Nov 2014 16:05:44 -0600
- Organization: New Artisans LLC
>>>>> Cedric Auger
>>>>> <sedrikov AT gmail.com>
>>>>> writes:
> I am sorry to have mentionned Empty_set for the base case. I meant "unit"
> (and you do not require the "S O" case, as "prod A unit" is isomorphic to
> "A").
Yes, I worked this out later today. :)
Another benefit of this approach is that I was able to make all use of vector
and fin disappear from the extracted Haskell code, where it now reduces down
to Int and [a], so cheers all around.
Emilio's suggestion about using ssreflect tuples is a great one -- since I'm
trying to use ssreflect more; I will investigate that avenue next.
John
- [Coq-Club] Question about a lemma concerning vectors, John Wiegley, 11/09/2014
- Re: [Coq-Club] Question about a lemma concerning vectors, Cedric Auger, 11/09/2014
- Re: [Coq-Club] Question about a lemma concerning vectors, John Wiegley, 11/09/2014
- Re: [Coq-Club] Question about a lemma concerning vectors, Adam Chlipala, 11/09/2014
- Re: [Coq-Club] Question about a lemma concerning vectors, John Wiegley, 11/10/2014
- Re: [Coq-Club] Question about a lemma concerning vectors, Emilio Jesús Gallego Arias, 11/10/2014
- Re: [Coq-Club] Question about a lemma concerning vectors, Cedric Auger, 11/10/2014
- Re: [Coq-Club] Question about a lemma concerning vectors, John Wiegley, 11/11/2014
- Re: [Coq-Club] Question about a lemma concerning vectors, Emilio Jesús Gallego Arias, 11/09/2014
- Re: [Coq-Club] Question about a lemma concerning vectors, Frédéric Blanqui, 11/12/2014
