coq-club - Re: [Coq-Club] algebraic hierarchy
  • From: Abhishek Anand <abhishek.anand.iitg AT gmail.com>
  • To: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] algebraic hierarchy
  • Date: Tue, 11 Nov 2014 15:10:44 -0500
Are there any examples of using Ring, SemiRing and Ordered SemiRings from MathClasses?
The CoRN library depends on it. So you can import files from the CoRN library and then use the Print Instances query.
Using the query "Print Instances MathClasses.interfaces.abstract_algebra.Ring", I found many uses, including the following :
https://github.com/c-corn/corn/blob/master/reals/fast/CRArith.v#L692
Other queries that might be useful for you are:  Locate, Print, Search, SearchAbout, SearchPattern
