coq-club - Re: [Coq-Club] Cube root function
  • From: Abhishek Anand <abhishek.anand.iitg AT gmail.com>
  • To: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Cube root function
  • Date: Tue, 18 Nov 2014 12:52:07 -0500
AFAIK, the reals in the standard library are axiomatically defined; you cannot compute with them in general.
If you want to compute with exact reals, look at the CoRN library.
http://corn.cs.ru.nl/
Note that real numbers (not to be confused with floats/doubles/triples....) are in some sense infinite objects.
When you compute a real number, you get a function that can be used to compute
arbitrarily close rational (finite) approximations to the represented real number.
In CoRN, there is a certified implementation of square roots using the Wolfram's method
https://github.com/c-corn/corn/blob/master/reals/faster/ARroot.v
For example usages, look at
https://github.com/c-corn/corn/blob/master/examples/RealFaster.v
The above implementations seems to be specialized for square roots.
I didn't find any specialized method for cube roots, or n^th roots.
I think that you can use computational content of the Intermediate Value Theorem (IVT) to
get an inefficient implementation of n^th roots for any positive natural n.
https://github.com/c-corn/corn/blob/master/ftc/StrongIVT.v
On Tue, Nov 18, 2014 at 2:56 AM, <ncyms8r3x2 AT snkmail.com> wrote:
I can't find a cube root function for reals in the standard library. Am I
missing it?
Is there another commonly used and more complete library for real numbers that
you can recommend?
