- From: Guillaume Melquiond <guillaume.melquiond AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Cube root function
- Date: Wed, 19 Nov 2014 14:49:36 +0100
On 19/11/2014 14:14, bertot wrote:
There is a function Rpower : R -> R -> R, It is more general than cube
root. As noted by B. Spitters, cube root can be implemented with the
help of logarithm and exponential. This is illustrated by the
definition of Rpower:
Coq < Print Rpower.
Rpower = fun x y : R => exp (y * ln x)
: R -> R -> R
Argument scopes are [R_scope R_scope]
There are a few theorems about Rpower, which may help you obtain most of
the results you may want to consider. If you want to compute this
function, there is the problem that you can of course only compute
approximations, so you are looking for ways to prove things like:
Lemma cubic_root_3_app1 : 14422 /10000 < Rpower 3 (1/3) < 14423/10000.
I feel compelled to show a more automatic proof:
Require Import Reals Interval_tactic.
(14422/10000 < Rpower 3 (1/3) < 14423/10000)%R.
Proof.
unfold Rpower.
split ; interval.
Qed.
Disclaimer: the "ln" function is not supported by any of the currently released version of CoqInterval, so the script above depends on the master branch of CoqInterval.
Best regards,
Guillaume
- [Coq-Club] Cube root function, ncyms8r3x2, 11/18/2014
- Re: [Coq-Club] Cube root function, Abhishek Anand, 11/18/2014
- Re: [Coq-Club] Cube root function, Bas Spitters, 11/18/2014
- Re: [Coq-Club] Cube root function, Kyle Stemen, 11/23/2014
- Re: [Coq-Club] Cube root function, bertot, 11/19/2014
- Re: [Coq-Club] Cube root function, Guillaume Melquiond, 11/19/2014
