- From: Pierre-Marie Pédrot <pierre-marie.pedrot AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Proving a theorem about a recursive function that uses Acc
- Date: Tue, 09 Dec 2014 00:02:58 +0100
On 08/12/2014 23:35,
lars.rasmusson AT sics.se
wrote:
> I'd be very thankful for an example proof, either using my formulation
> (which
> is intended to be close to how I would write the function in Ocaml, or
> perhaps
> structured differently, if it makes the proving easier.
(Warning: maybe off topic?)
Dunno if that counts as a change of formulation, but you can just get
rid of the Acc function in this particular case:
Fixpoint pick (l : list nat) : list nat := match l with
| nil => nil
| cons n l =>
let fix F (n : nat) (l : list nat) {struct l} := match n with
| 0 => pick l
| S n =>
match l with
| nil => nil
| cons _ l => F n l
end
end in
cons n (F n l)
end.
I know that defeats the purpose of using accessibility proofs, but
that's always better not to rely on them when you do not have to...
PMP
signature.asc
Description: OpenPGP digital signature
- [Coq-Club] Proving a theorem about a recursive function that uses Acc, lars.rasmusson, 12/08/2014
- Re: [Coq-Club] Proving a theorem about a recursive function that uses Acc, Pierre-Marie Pédrot, 12/09/2014
- Re: [Coq-Club] Proving a theorem about a recursive function that uses Acc, lars.rasmusson, 12/09/2014
- Re: [Coq-Club] Proving a theorem about a recursive function that uses Acc, James Wilcox, 12/09/2014
- Re: [Coq-Club] Proving a theorem about a recursive function that uses Acc, Lars Rasmusson SICS, 12/09/2014
- <Possible follow-up(s)>
- Re: [Coq-Club] Proving a theorem about a recursive function that uses Acc, julien . forest, 12/09/2014
