- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Proving a theorem about a recursive function that uses Acc
- Date: Tue, 09 Dec 2014 07:34:30 +0100
Hi Lars,
here is a version of your development using Function (which helps you
to deal with no structural functions).
Hope this helps,
Best regards,
Julien
On Mon, 08 Dec 2014 23:35:55 +0100
<lars.rasmusson AT sics.se>
wrote:
Salut à tous!
I'm trying to understand how to work with recursive functions where I
have to use Acc to prove termination, and I made a small example
function, "pick".
"pick" takes a "list nat" that starts with "n", then drops the "n"
following elements, and then does "picksome" on the rest.
I.e. pick [1,2,3,4,5] = [1,3]
(take the "1", then drop 1 (i.e. drop the "2"), then take the "3" ,
drop the next 3 items, i.e the "4" and "5", and then end)
I am able to prove that the function terminates alright, but I want
to prove a lemma that given a list of all zeros, picksome will return
the same list: forall l, allzeros l -> picksome l = l.
(take the first zero, drop zero elements, take the next zero, drop
zero elements, ......)
However, the proof of this lemma gets all tangled upp with the
Accesibility term, and it quickly gets out of hand. How should one
structure this kind of proof to make it feasible, and so that I don't
have to deal with the Acc term (which ideally should be irrelevant
for the proof)?
I posted a small development here
https://gist.github.com/larsr/3a4f8997e5ad0d6d98e0
I'd be very thankful for an example proof, either using my
formulation (which is intended to be close to how I would write the
function in Ocaml, or perhaps structured differently, if it makes the
proving easier.
Thanks!
/Lars
Require Import Arith.
Require Import List.
Import ListNotations.
Require Import Recdef.
Function drop {T} n (l:list T) :=
match n,l with
| S n', cons _ l' => drop n' l'
| O, _ => l
| _, _ => nil
end.
Lemma drop_lemma_le : forall {T} n (l:list T), length (drop n l) <= (length
l).
Proof.
intros; generalize n; induction l; intros; destruct n0; try reflexivity;
apply le_S; apply IHl.
Defined.
Function pick (l: list nat) { measure length l } :=
match l with
nil => nil
| cons a l' => cons a (pick (drop a l'))
end.
Proof.
intros l a l' teq.
subst l.
simpl.
apply le_lt_n_Sm.
apply drop_lemma_le.
Defined.
Inductive zerolist : list nat -> Prop :=
| znil : zerolist nil
| hzlist : forall l, zerolist l -> zerolist (O::l).
(* We can prove our theorem if we have the lemma H *)
Theorem pickzero': (forall k, pick (0::k) = 0::pick k) ->
forall l, zerolist l -> pick l = l.
Proof.
intros H l H0; induction H0; [ | rewrite H; rewrite IHzerolist];
reflexivity.
Qed.
(* but trying to prove the lemma *)
Lemma pickzero_lemma : forall k, pick (0::k) = 0::pick k.
Proof.
intros k.
rewrite pick_equation.
reflexivity.
Qed.
- [Coq-Club] Proving a theorem about a recursive function that uses Acc, lars.rasmusson, 12/08/2014
- Re: [Coq-Club] Proving a theorem about a recursive function that uses Acc, Pierre-Marie Pédrot, 12/09/2014
- Re: [Coq-Club] Proving a theorem about a recursive function that uses Acc, lars.rasmusson, 12/09/2014
- Re: [Coq-Club] Proving a theorem about a recursive function that uses Acc, James Wilcox, 12/09/2014
- Re: [Coq-Club] Proving a theorem about a recursive function that uses Acc, Lars Rasmusson SICS, 12/09/2014
- <Possible follow-up(s)>
- Re: [Coq-Club] Proving a theorem about a recursive function that uses Acc, julien . forest, 12/09/2014
