Re: [Coq-Club] Applying Rational Absolute value triangle inequality on multiple terms
- From: Guillaume Melquiond <guillaume.melquiond AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Applying Rational Absolute value triangle inequality on multiple terms
- Date: Tue, 09 Dec 2014 22:26:39 +0100
On 09/12/2014 22:04, Daniel Galvez wrote:
Can anyone describe to me how to add parenthese in an expression (such as
turning the first expression into the second expression)? The larger program I
need this statement in makes it such that I cannot simply insert parantheses
manually where I need this proof.
You can either do it by hand by applying the corresponding rewriting rules:
unfold Qminus.
rewrite <- Qplus_assoc.
or you can let a tactic like ring or field do the proof for you automatically:
setoid_replace (a - b + c - d) with ((a - b) + (c - d)) by ring.
Whichever solution is better depends on how many rewriting steps you need to achieve the desired result.
Best regards,
Guillaume
- [Coq-Club] Applying Rational Absolute value triangle inequality on multiple terms, Daniel Galvez, 12/09/2014
- Re: [Coq-Club] Applying Rational Absolute value triangle inequality on multiple terms, Guillaume Melquiond, 12/09/2014
