- To: coq-club AT inria.fr
- Subject: [Coq-Club] Equality
- Date: Tue, 9 Dec 2014 21:53:03 -0300
Hi,
I need to compare values of the type PATH defined below
Definition ID := string.
Inductive STEP : Type :=
| LastStep : ID -> STEP | Step : ID -> PATH -> STEP | Init : ID -> STEP
with PATH : Type := Path : list STEP -> PATH.
Is there a way to compare those values in Gallina like we compare them in SML?
I tried the suggestion in http://stackoverflow.com/questions/6636131/searching-through-a-list-recursively-in-coq
Definition PATH_dec : forall x y : ID, {x = y} + {x <> y}.
Proof. decide equality. Defined.
but Coq says Error: Attempt to save an incomplete proofCompilation output:
Thanks in advance,
Saulo
- [Coq-Club] Equality, Saulo Araujo, 12/10/2014
- Re: [Coq-Club] Equality, Nuno Gaspar, 12/10/2014
- Re: [Coq-Club] Equality, Saulo Araujo, 12/10/2014
- Re: [Coq-Club] Equality, Frédéric Blanqui, 12/10/2014
- Re: [Coq-Club] Equality, Kyle Stemen, 12/10/2014
- Re: [Coq-Club] Equality, Saulo Araujo, 12/11/2014
- Re: [Coq-Club] Equality, Strub, Pierre-Yves, 12/10/2014
- Re: [Coq-Club] Equality, Cedric Auger, 12/10/2014
