coq-club - [Coq-Club] Question on Type Class Substructures
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] Question on Type Class Substructures
  • Date: Wed, 10 Dec 2014 17:30:32 +0100
Dear Coq Users,
I have a question on Type Class Substructures as descibed in the reference
manual section 19.5.2. I tried the example given in the manual:
Require Import Arith.
Definition relation (A : Type) := A->A->Prop.
Class Reflexive (A : Type) (R : relation A) := reflexivity : forall x, R x x.
Class Transitive (A : Type) (R : relation A) := transitivity : forall x y z, R
x y -> R y z -> R x z.
Class PreOrder (A : Type) (R : relation A) := {
PreOrder_Reflexive :> Reflexive A R ;
PreOrder_Transitive :> Transitive A R
Definition NatLERefl : Reflexive nat le.
Proof. unfold Reflexive. apply le_n. Qed.
Definition NatLETrans : Transitive nat le.
Proof. unfold Transitive. apply le_trans. Qed.
Definition NatLEPreOrder : PreOrder nat le.
Proof. constructor. apply NatLERefl. apply NatLETrans. Qed.
(* The manual claims that in this situation any PreOrder can be used when a
reflexive or transitive relation is expected, so I assume they type check as
such. But when I try the below assignment, it doesn't type check: *)
Definition testPreorderIsRefl : Reflexive nat le := NatLEPreOrder.
(* A side note: the same does work using a record with implicit coercion *)
Record PreOrder' (A : Type) (R : relation A) := {
PreOrder_Reflexive' :> Reflexive A R ;
PreOrder_Transitive' :> Transitive A R
Definition NatLEPreOrder' : PreOrder' nat le.
Definition testPreorderIsRefl : Reflexive nat le := NatLEPreOrder'.
Does somehone have an example on Type Class Substructures, which illustrates
the concept?
Thanks & best regards,
Michael
