coq-club - Re: [Coq-Club] Question on Type Class Substructures
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Question on Type Class Substructures
  • Date: Wed, 10 Dec 2014 18:27:44 +0100
Hi Michael,
there is no type class instance needed here, and actually you have
not declared
any instance (using keyword Instance instead of Definition), apart
from the ones declared
with :> (beware that this syntax has a slightly different meaning in
Class declarations and
Record declarations).
Require Import Arith.
Definition relation (A : Type) := A->A->Prop.
Class Reflexive (A : Type) (R : relation A) := reflexivity : forall x, R x x.
Class Transitive (A : Type) (R : relation A) := transitivity : forall x y z, R
x y -> R y z -> R x z.
Class PreOrder (A : Type) (R : relation A) := {
PreOrder_Reflexive :> Reflexive A R ;
PreOrder_Transitive :> Transitive A R
Definition NatLERefl : Reflexive nat le.
Proof. unfold Reflexive. apply le_n. Qed.
Definition NatLETrans : Transitive nat le.
Proof. unfold Transitive. apply le_trans. Qed.
Instance NatLEPreOrder : PreOrder nat le.
Proof. constructor. apply NatLERefl. apply NatLETrans. Qed.
(* The manual claims that in this situation any PreOrder can be used when a
reflexive or transitive relation is expected, so I assume they type check as
such. But when I try the below assignment, it doesn't type check: *)
Definition testPreorderIsRefl : Reflexive nat le := _. (* This uses
NatLEPreOrder and the PreOrder_Reflexive sub-instance* )
Best,
-- Matthieu
2014-12-10 17:30 GMT+01:00
<michael.soegtrop AT intel.com>:
> Dear Coq Users,
> I have a question on Type Class Substructures as descibed in the reference
> manual section 19.5.2. I tried the example given in the manual:
> x.
> z, R
> Definition NatLEPreOrder : PreOrder nat le.
> Definition testPreorderIsRefl : Reflexive nat le := NatLEPreOrder.
> (* A side note: the same does work using a record with implicit coercion *)
> Record PreOrder' (A : Type) (R : relation A) := {
> PreOrder_Reflexive' :> Reflexive A R ;
> PreOrder_Transitive' :> Transitive A R
> Definition NatLEPreOrder' : PreOrder' nat le.
> Definition testPreorderIsRefl : Reflexive nat le := NatLEPreOrder'.
> Does somehone have an example on Type Class Substructures, which illustrates
> the concept?
> Thanks & best regards,
> Michael
-- Matthieu
