- From: Quentin Carbonneaux <quentin.carbonneaux AT yale.edu>
- To: coq-club AT inria.fr
- Subject: [Coq-Club] Working with sums.
- Date: Wed, 10 Dec 2014 13:23:53 -0500
Hello everyone,
I am using Coq to make a formalization of a program analysis
I already implemented. This analysis works like a Hoare Logic
by building a derivation inductively on the syntax.
What plays the role of pre/postconditions in my system are
what I call "annotations". In essence, they are maps from
"indices" to Z. My definition for them is obvious
Definition annot := index -> Z.
Indices are built from program variables. In my current
implementations there are only two kind of indices but, in
the future, I will have to add more.
Inductive index := iConst | iInter (a b: var).
The type var is here to represent program variables, I left
it abstract.
My problem comes when defining the semantics of annotations.
These annotations are meant to represent functions from
heaps to Z. Annotations are simply coordinates in the linear
algebra sense (except that Z is not a field...). If Q is an
annotation, I want
semantics Q h = \sum_i (Q i) * base i h
Definition base (i: index) (h: heap) :=
match i with
| iConst => 1
| iInter a b => Z.max (h b - h a) 0
end.
Now my problem is how to define the above sum over all possible
indices. First, it only makes sense when, either Q is non-zero
for only a finite number of indices (this is what I have on
paper), or the number of variables (hence indices) is finite.
My current solution is to have as a parameter the list of indices
we focus on, and then define my semantics function as follows:
Parameter indices: list index.
Definition semantics (Q: annot) (h: heap) :=
List.fold_right (fun i n => n + Q i * base i h) 0 indices.
But this definition is far from ideal:
+ indices is a list when what I mean is a finite set (i.e. I
don't want duplicates)
+ presented as a fold, the sum is essentially non-commutative
which makes many proofs really painful
+ the order imposed by the indices list is often a contraint
when reasoning
Here is an example lemma that I barely mention in my paper
proof but takes a lot of Coq to go through.
Definition pay (Q: annot) (n: Z) (i: index) :=
match i with
| iConst => Q iConst - n
| i => Q i
end.
Lemma semantics_pay:
forall (Q: annot) (h: heap) (n: Z),
semantics Q h = semantics (pay Q n) h + n.
Proof. (* long! *) Qed.
If you have experience dealing with sums like this, could you
please help me clean this development and tell me how reasoning
can be made with less pain.
Thank you!
PS: Please CC me if you respond, I am not subscribed yet.
-- Quentin
- [Coq-Club] Working with sums., Quentin Carbonneaux, 12/10/2014
