coq-club - Re: [Coq-Club] Error: Conclusion depends on the body of f
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Error: Conclusion depends on the body of f
  • Date: Fri, 12 Dec 2014 22:09:40 -0500
I don't know of any way to get Coq to print all that hidden stuff, but
here are some tactics that might help you probe... The main idea is
that 'cbv delta' will work even if you cannot see the identifier using
the 'match' tactic.
(* Unfolds x everywhere before clearing its body *)
Ltac clearbody' x := cbv delta [x] in *; clearbody x.
(* Test whether an identifier is present in the goal or hyp without
altering it *)
(* if x is present in the goal: idtac, otherwise: fail *)
Ltac test_dep x := ( (cbv delta [x] || fail 1); fail) || idtac.
Ltac test_dep_in x H := ( (cbv delta [x] in H || fail 1); fail) || idtac.
(* Succeeds only if x is 'hidden' in g (i.e. we are unable to match x,
but it is there) *)
Ltac is_hidden_dep_in_constr x g:=
match g with
| context[x] => fail 1
| _ => test_dep x
end.
(* Lists all 'hidden' identifiers within a goal *)
Ltac show_hidden_deps_in_goal:=
idtac "Hidden dependencies in goal:";
try match goal with
| x: _ |- ?g => is_hidden_dep_in_constr x g; idtac x; fail
end.
(* Lists all 'hidden' identifiers within a hyp*)
Ltac show_hidden_deps_in_hyp H:=
idtac "Hidden dependencies in" H ":";
try match goal with
| x: _ |- _ => match type of H with
| _ => test_dep_in x H; idtac x; fail
end
end.
(* Lists all 'hidden' identifiers *)
Ltac show_hidden_deps_in_all:=
try match goal with
| H: _ |- _ => show_hidden_deps_in_hyp H; fail
end;
show_hidden_deps_in_goal.
Tactic Notation "show_hidden_deps" := show_hidden_deps_in_goal.
Tactic Notation "show_hidden_deps" "in" hyp(H) := show_hidden_deps_in_hyp H.
Tactic Notation "show_hidden_deps" "in" "*" := show_hidden_deps_in_all.
Goal let f:=nat in let g:=bool in let m:=true in let n:=0 in True.
intros f g m n.
change nat with f in n.
change bool with g in m.
Fail test_dep f. (* f is not present *)
revert m n.
test_dep f.
test_dep g.
show_hidden_deps.
show_hidden_deps in f.
show_hidden_deps in *.
Fail clearbody f.
clearbody' f.
clearbody' g.
exact I.
Qed.
