- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Error: Conclusion depends on the body of f
- Date: Sat, 13 Dec 2014 02:21:53 -0500
Other than the let..in expression, I'm not sure if there is another
source of "hidden" terms. For whatever reason, you can write a pattern
that matches against the type, but Coq ignores it:
let g:= constr:(let x:nat:= 0 in True) in
match g with
| let x:bool := _ in _ => idtac "bool"
| let x:nat := _ in _ => idtac "nat"
end.
Coq generates a warning, "Cast not taken into account in constr
pattern," and the output is "bool."
However, there is a workaround -- match the subterm of let..in as a function:
match g with
| let x := _ in (@?z x) => match z with
| (fun _:bool => _) => idtac "bool"
| (fun _:nat => _) => idtac "nat"
end
end.
The output of this is "nat," as we would expect. (This works with
context[...] too!)
So now that I think about it, you might just want the following tactic
in order to see all of those "hidden" types:
Ltac let_to_fun :=
repeat match goal with
| |- context[?t] => match t with
| let x := ?y in (@?z x) =>
change t with (z y)
end
end.
-cj
- [Coq-Club] Error: Conclusion depends on the body of f, Jonathan, 12/11/2014
- Re: [Coq-Club] Error: Conclusion depends on the body of f, CJ Bell, 12/13/2014
- Re: [Coq-Club] Error: Conclusion depends on the body of f, Jonathan, 12/13/2014
