coq-club - Re: [Coq-Club] type coercions
  • To: Cedric Auger <sedrikov AT gmail.com>, Guillaume Melquiond <guillaume.melquiond AT inria.fr>
  • Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] type coercions
  • Date: Thu, 1 Jan 2015 09:45:18 +0100
Hi,
In the development version (8.5), there is a set of "standard"
notations for eq_rect and eq_rect_r to "get it right" quicklier:
Import EqNotations. (* From Logic.v *)
Definition test0 {A B:Type} {H:A=B} (a:A) : B := rew [fun X => X] H in a.
or even:
Import EqNotations.
Definition test0 {A B:Type} {H:A=B} (a:A) : B := rew H in a.
To achieve this in 8.4, one would need the following
Import EqNotations.
Notation "'rew' [ P ] H 'in' H'" := (eq_rect _ P H' _ H)
(at level 10, H' at level 10,
format "'[' 'rew' [ P ] '/ ' H in '/' H' ']'").
Happy 2015,
Hugo
On Tue, Dec 30, 2014 at 10:44:24PM +0100, Cedric Auger wrote:
> You can also be more low level by unfolding eq_rect.
> I did not tried it, but I guess that the following would work:
>   match H in _=T return T with eq_refl => a end.
> I do not know if coq has improved annotations inference. Maybe the following
> would also work:
> Definition test0 {A B:Type} {H:A=B} (a:A) : B := let () := H in a.
> 2014-12-30 20:21 GMT+01:00 Guillaume Melquiond
> <guillaume.melquiond AT inria.fr>:
> On 30/12/2014 20:01, Vadim Zaliva wrote:
> Is it possible to do something like this:
> Program Definition test0 {A B:Type} {H:A=B} (a:A) : B := a.
> I would like using 'H' cast (coerce?) 'a' to type 'B'.
>   eq_rect A (fun C => C) a B H.
> Note that, except for a few people, I don't expect anyone to get the
> formula right on the first try. Here is how I obtained it:
> Definition test0 {A B:Type} {H:A=B} (a:A) : B.
> Proof.
>   rewrite <- H.
>   exact a.
> Defined.
> Best regards,
> Guillaume
  • Re: [Coq-Club] type coercions, Hugo Herbelin, 01/01/2015
