- To: coq-club AT inria.fr
- Subject: [Coq-Club] Simplifying fix expressions
- Date: Wed, 31 Dec 2014 16:08:59 -0500
Is it possible to simplify fixed point expressions over non-constant
arguments? The Eval command and the lazy and cbv tactics can be used to simplify these expressions over constants. For example: Eval lazy iota in ((fix f (x : nat) := if eq_nat_dec x 0 then true else false) 1). evaluates to (fun (x : nat) => if eq_nat_dec x 0 then true else false) 1. but Eval lazy iota in ((fix f (x : nat) := if eq_nat_dec x 0 then true else false) y). should evaluate to (fun (x : nat) => if eq_nat_dec x 0 then true else false) y but does not simplify at all. Is there something that I'm missing? Thanks, Larry |
- [Coq-Club] Simplifying fix expressions, Larry Lee, 12/31/2014
- Re: [Coq-Club] Simplifying fix expressions, Pierre Boutillier, 01/05/2015
- Re: [Coq-Club] Simplifying fix expressions, Pierre Courtieu, 01/05/2015
