coq-club - Re: [Coq-Club] Simplifying fix expressions
  • From: Pierre Boutillier <pierre.boutillier AT pps.univ-paris-diderot.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Simplifying fix expressions
  • Date: Mon, 5 Jan 2015 13:04:34 +0100
> On 31 Dec 2014, at 22:08, Larry Lee
> <llee454 AT gmail.com>
> wrote:
> Is it possible to simplify fixed point expressions over non-constant
> arguments?
euhhh nope. Your enemy is called strong reduction
> Eval lazy iota in ((fix f (x : nat) := if eq_nat_dec x 0 then true else
> false) y).
> should evaluate to
> (fun (x : nat) => if eq_nat_dec x 0 then true else false) y
> but does not simplify at all.
> Is there something that I'm missing?
Indeed, you miss the fact that you’re discussing over a very special kind of
fixpoints: the one that always reach a normal form in 1 unfolding !
Because Coq is doing strong reduction, I’m glad that it unfold fixpoints only
if the recursive argument starts by a constructor. I would be annoyed that
(fix pl x := match x with | 0 => y | S m => S (pl m) end) n unfolds to
(fun x := match x with | 0 => y | S m => S ((fix pl x := match x with | 0 =>
y | S m => S (pl m) end) m) end) n that unfolds to
(fun x := match x with | 0 => y | S m => S ((fun x := match x with | 0 => y |
S m => S ((fix pl x := match x with | 0 => y | S m => S (pl m) end) m) end)
… you’ve understood my point :-)
> Thanks,
> Larry
All the best,
Pierre B.
