- To: Coq Club <coq-club AT inria.fr>
- Subject: [Coq-Club] question about evar instance "trapped" under binders
- Date: Tue, 06 Jan 2015 19:10:30 -0500
Is it possible in Coq for an evar instance to exist in a goal such that it is "trapped" under binders? Meaning that after all possible intros are done, the evar instance still can't be found using Ltac's context[] construct (as in [match .. with context[?V] => is_evar V ...], but has_evar senses it)? Any case of an evar instance "trapped" under binders would seem to require that its type depends on bound variables. I can construct such cases within the conclusion of a goal, but they would become untrapped by doing sufficient intros, at which point context[] can find them. I can't seem to construct any cases in hypotheses (trapped under vars bound in the hypothesis), however. But, that's certainly not proof that it isn't possible.
If such trapped evar instances are possible, can anyone come up with an example?
-- Jonathan
- [Coq-Club] question about evar instance "trapped" under binders, Jonathan Leivent, 01/07/2015
- Re: [Coq-Club] question about evar instance "trapped" under binders, Jason Gross, 01/08/2015
- Re: [Coq-Club] question about evar instance "trapped" under binders, Jonathan Leivent, 01/08/2015
