- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] question about evar instance "trapped" under binders
- Date: Thu, 08 Jan 2015 11:26:52 -0500
On 01/08/2015 12:21 AM, Jason Gross wrote:
I do not have access to Coq at the moment, but does something like this
work?
Goal Type.
refine ((fun (x : nat) (y : _) => _) = (fun (x : nat) (y : _) => _)).
No - that actually loses its binders completely - which isn't what I would have expected either. However, a variation of that is sufficient to create a case of what I was looking for:
Goal True.
refine (let f := (fun (x : nat) (y : _ ) => _) in _); shelve_unifiable.
Thanks.
-- Jonathan
On 1:11am, Wed, Jan 7, 2015 Jonathan Leivent
<jonikelee AT gmail.com>
wrote:
Is it possible in Coq for an evar instance to exist in a goal such that
it is "trapped" under binders? Meaning that after all possible intros
are done, the evar instance still can't be found using Ltac's context[]
construct (as in [match .. with context[?V] => is_evar V ...], but
has_evar senses it)? Any case of an evar instance "trapped" under
binders would seem to require that its type depends on bound variables.
I can construct such cases within the conclusion of a goal, but they
would become untrapped by doing sufficient intros, at which point
context[] can find them. I can't seem to construct any cases in
hypotheses (trapped under vars bound in the hypothesis), however. But,
that's certainly not proof that it isn't possible.
If such trapped evar instances are possible, can anyone come up with an
example?
-- Jonathan
- [Coq-Club] question about evar instance "trapped" under binders, Jonathan Leivent, 01/07/2015
- Re: [Coq-Club] question about evar instance "trapped" under binders, Jason Gross, 01/08/2015
- Re: [Coq-Club] question about evar instance "trapped" under binders, Jonathan Leivent, 01/08/2015
