- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Co-induction with existential quantification?
- Date: Sat, 10 Jan 2015 10:16:56 +0100
On 10/01/15 05:04, Hongjin Liang wrote:
> Require Import Relations.
> Variable Node : Type.
> Variable edge : relation Node.
> CoInductive InfPath : Node -> Prop :=
> | infpath : forall x y,
> edge x y ->
> InfPath y ->
> InfPath x.
> CoInductive Trace : Type :=
> | cons : Node -> Trace -> Trace.
> CoInductive InfPathWithTrace : Node -> Trace -> Prop :=
> | infpathtr : forall x y T,
> edge x y ->
> InfPathWithTrace y T ->
> InfPathWithTrace x (cons x T).
> Lemma infPath_existTrace :
> forall x, InfPath x -> exists T, InfPathWithTrace x T.
> Perhaps this lemma is actually incorrect? Any idea or suggestion is greatly
> appreciated.
As a general guideline,
induction lets you prove statements of the shape
inductive-hypothesis -> ...
and coinduction lets you prove statements of the shape
... -> coinductive-conclusion
Your lemma has shape
coinductive-hypothesis -> inductive-conclusion
so neither induction nor coinduction will help.
The trick is to explicitly construct (with a CoFixpoint) the trace T
such that InfPathWithTrace x T holds:
CoFixpoint TraceofInfPath (x: Node) (ip: InfPath x) : Trace := ...
Lemma infPath_trace:
forall x (ip: InfPath x), InfPathWithTrace x (TraceofInfPath x ip).
Proof ... Qed.
Proof.
intros x ip. exists (TraceofInfPath x ip). apply infPath_trace.
Qed.
The construction of the trace is not obvious because InfPath is in
Prop while Trace is in Type.
Solution #1: put InfPath in Type.
CoInductive InfPath : Node -> Type :=
edge x y ->
InfPath y ->
InfPath x.
match ip with
| infpath x y edge inf => cons x (TraceofInfPath y inf)
end.
Solution #2: use classical logic, e.g. an axiom of description.
Require Import ClassicalEpsilon.
Definition invertInfPath (x: Node) (ip: InfPath x)
: { y | edge x y /\ InfPath y }.
Proof.
apply constructive_indefinite_description.
inversion ip; subst. exists y; auto.
Qed.
match invertInfPath x ip with
| exist y (conj edg inf) => cons x (TraceofInfPath y inf)
end.
Hope this helps,
- Xavier Leroy
- [Coq-Club] Co-induction with existential quantification?, Hongjin Liang, 01/10/2015
- Re: [Coq-Club] Co-induction with existential quantification?, Xavier Leroy, 01/10/2015
- Re: [Coq-Club] Co-induction with existential quantification?, Hongjin Liang, 01/11/2015
